well just checked my oil
just checked my oil and the thing was bone dry,someone told me that rodeos are a pig on oil,i dont see any smoke or doesnt smell like im burning oil.
can this be true???
99 RODEO -R.I.P 01 rodeo -5" independent 4x lift 9000 rancho shocks manual locking hubs 18x9.5 BBS rims 285/60/18 toyo open country A/T 02 honda passport leather int 15x10old school rims on 33x12 roughrider A/T |
Re: well just checked my oil
yup. Some report burning up to 1 qt per 500 miles. watch it like a hawk.
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
Is the truck new to you? What prompted you to check the oil? Lifter tick?
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K '96 Jetta 249K '97 TJ 156K '02 VW Cabrio 70K '03 E46 107K |
Throw in some Rotella 5w-40 synthetic, this is a thicker oil and should hopefully aid in keeping it in the sump longer.
Also, this oil is very highly recommended by a long time Isuzu specialist for assisting in keeping these engines clean with minimal wear. You can find it at Walmart.
1997 3.2L V6 Rodeo 32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack On it's way to 185k strong ![]() 2004 3.4L Tacoma TRD off-road 4x4 Double cab 32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
You meant any oil from Rotella or just 5W-40. I just change mine Rotella 15w-40 from wal-mart. Thanks. |
Personally, I think the Rotella 5w-40 is perfect for these engines.
No, I'm not referring to just *any* Rotella oil, but rather the above viscosity. Or, you could run the 15w-40 in summer and 5w-40 in winter; I would not be running a 15w-40 in temps below 30F in these engines. Oil will be WAY too thick to reach the lifters and you will hear MUCH MUCH more tapping!
so whats better for it in the summer cause in the winter it gets to -40c to -45c sometimes i dont know what that is in F
at -40* exactly it's exactly the same, surprisingly
-40*C = -40*F //bc
1992 trooper 3.2L v6 sohc automatic...as is i love a good intermittent electrical challenge. . .especially when it's someone else's. |
so is it recommened to use 5w-40 or 15w-40
or is the oil i used ( 4x4 SUV special blend Qstate) just as good or is the 5w-40 to thick for the wheater conditions in winnipeg(canada) im not saying it is -40 all the time here but i just dont want to find out that i cant start the truck and then im screwed
If what TrooperBC stated is correct; i.e. -40*C = -40*F
Then NO you would NOT want a 15w-40 in that engine in weather that cold, your oil pump won't turn. You need to run a synthetic 0w-30 or 5w-30 for temps that cold in the winter; there's NO WAY I would EVER run even a 15w-40 in Canada winters, not even in summer. Find yourself a good synthetic 0w-30 or 5w-30 and run it year round; I would NOT be running even a 10w-30 or 10w-40 - it's just too thick for your temps.
First off, I drive a 93 Rodeo 3.2L V6 automatic 4x2, so..
I'm definitely into the Rotella oil, but should I use 5w40 or 15w40? Where I live, the summer highs are 125F and winter lows are certainly (well) above 40F. Most of the year it's much closer to the hot side, for example today 9/15 was 102. I was planning on going for the 5w40, but should I spring for the thicker 15? (For the record, right now it has Shell 10w40. It's not actually the Rotella T brand, though.) |
