Old 08-27-2007, 06:44 PM
luminafan79 luminafan79 is offline
a/c stops blowing thru vents when I accelerate
Hello everyone. I just bought a 1999 LUmina ltz with 62000 miles. The car is in excellent condition. The problem I have is that when I accelerate, the a/c stops blowing thru the vents and blows down at my feet. As soon as I let up on the gas, it returns. Does anyone have any ideas as to how to fix this? If so, can you tell me where to find the faulty parts? Also, the daytime running lamps do not work.
Ozzy
Old 08-28-2007, 12:21 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: a/c stops blowing thru vents when I accelerate
If you've done any work around the battery lately, check the HVAC vacuum supply line that runs near it, behind the washer fluid bottle and then to the firewall. It is very common for this line to get inadvertently damaged/cracked, and will cause what you describe. The engine produces very low vacuum while accelerating, and a leak will be most noticeable when doing so.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
