Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-27-2007, 04:11 PM
thunderchicken2 thunderchicken2 is offline
No power
Ok, so first things first, any help would be greatly appreciated. My car has sat in the driveway long enough, and I want to get it running.
The other day, I was about 5 miles from home, when I felt the car buck really bad multiple times before I got to the house. After checking around I noticed a lose connection to the MAF, coming from the MAF translator and decided that this was of course my problem. I fixed the connection and started the car, everything runs just fine now. Except when it goes. Every time I take the car out, it has absolutely NO power, and am lucky to get it up to 60mph max. on the open highway. It shows normal boost, even though the accelerator is to the floor for about a mile before I can gain any type of speed. I have checked multiple times for boost leaks, and even replaced all of the hoses involved in the turbo system. I also replaced the spark plugs and wires after all this happened, but it had no effect.
Any ideas? It has been suggested to me that the timing belt may have slipped.. Thank you all for taking time to read this.
2004 Dodge SRT-4
- K&N Ram Air Intake
- AGP wg
- HKS SSQ BOV
- AEM UEGO wideband
- stock boost gauge
- Full 3" custom exhaust w/ Magnaflow muffler
- Rerouted vaccuum lines
Old 08-27-2007, 04:18 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: No power
Not saying the timing belt is the cause, but have you checked your timing to make sure this is indeed not the cause?
1991 GSX 2.3 Stroker
Old 08-27-2007, 04:22 PM
Re: No power
I haven't yet, but I was just looking for different opinions of probable causes. I have been told many different things by different people, and am not sure where to start.. I'm guessing that would be a good starting point.
2004 Dodge SRT-4
- AGP wg
- HKS SSQ BOV
- AEM UEGO wideband
- stock boost gauge
Old 08-27-2007, 04:35 PM
defiancy's Avatar
Re: No power
I would check that, and if you have access to any spare parts (Via friends whatever) I would also swap in an ECU/ECM to see what that does.
Those would be the most logical starting point to the wonderful process of elimination.
Old 08-27-2007, 04:57 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: No power
First of all, how does the car run at idle, under heavy accelearation, and at normal crusing speeds? Does it stumble and sputter? If so, you may have jumped a tooth, otherwise it could be something else. I would do a compression test right off the bat just to get a general idea of what's goin on inside the motor.
95 Talon TSI AWD
97 Eclipse GST
Old 08-27-2007, 07:34 PM
Re: No power
Ok, it seems to run normal at idle within the usual RPM range with little or no surge. Under heavy acceleration well...there is no heavy acceleration. Even with the accelerator to the floor it will only slowly, and I mean SLOWLY, gain in speed. When I am finally able to run it at normal cruising speeds, it runs pretty smooth, with the exception of any power at all. There really is no stumble or sputter that i have noticed after I fixed the MAF connection. It's wierd that the rpm's will rise, but haven't the power to match it. Could it have been damaged in the 5 miles that I drove it with a bad connection to the MAF?
After searching around I'm not seeing the symptoms of the timing being off, I'm starting to think that it's more engine internal, which scares me. I will do a compression test and check the timing tomorrow, just to rule out anything that is not the problem. I will be back with the results in the morning.
2004 Dodge SRT-4
- AGP wg
- HKS SSQ BOV
- AEM UEGO wideband
- stock boost gauge
