Old 08-27-2007, 04:00 PM
rjeffery rjeffery is offline
A/C Freezing Up?
My A/C works fine most of the time, but after driving on the highway for long periods of time (>2 hrs.) the A/C stops blowing cold, and blows weak, even when on the max setting. If I turn the blower and the A/C off for a while then back on, it works fine again.
It seems like something is freezing up as it has much of the same symptoms that a home A/C unit does that freezes up.
I checked the system pressure before summer started with a Wal-Mart kit and it checked out ok.
I don't have much experience with A/C systems, so any input would be appreciated.
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 08-27-2007, 04:52 PM
bigbadram51 bigbadram51 is offline
Re: A/C Freezing Up?
Sounds to me like its low on coolant. I would take it to a pro to at least diagnose. Maybe with the "wal-mart kit" it has bee n leaking since you checked it.
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
Old 08-27-2007, 07:27 PM
maxwedge maxwedge is online now
A990 racer
Sounds like the evaporator is freezing and blocking air flow if as you say the blower volume is noticeably decreased. Only checking low and high side pressures and proper air flow over the evap will allow you to properly diagnose this.
Old 08-28-2007, 10:30 AM
Is this something that can be done at home, or does it require special tools/equipment that only a pro would have?
Thanks for the responses, I will keep you all posted.
Old 08-28-2007, 11:12 AM
taillight taillight is offline
It sounds like you have to much freon in the system. You need to use guages to tell. Some times they can be rented from auto parts stores.
Old 08-28-2007, 08:31 PM
rrousou rrousou is offline
My '96 did the same thing. I ended up replacing the compressor cycling switch on the aculmulator or whatever it is called as the compressor was engaged too long
