Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 08-27-2007, 12:25 PM
1996GMCJimmy 1996GMCJimmy is offline
Question Starting Problems with Fuel Pump?
A couple days ago my 1996 JIMMY would crank but not start right after my mechanic finished intalling breaks. My mechanic said that its a sign that my Fuel Pump might be going bad. After a few kicks on the fuel tank and a few turning key it started and has not given me problems at all since then (3 days ago).
I thought fuel pumps just go bad and just stop working! could it be the relay? fuel filter? I can hear the buzzing sound when I turn the ignition, meaning the the fuel pump is working, but I just dont know if It in fact it is the fuel pump of not.
I replaced it once, 5 years and 100,000 miles ago. Is it time for a new one?
Thanks
Old 08-27-2007, 02:46 PM
maxwedge maxwedge is offline
A990 racer
Re: Starting Problems with Fuel Pump?
Check the fuel pressure, this will answer all your questions, 60-65 psi.
Old 08-27-2007, 03:30 PM
samprix samprix is offline
I tried bumping the fuel tank, as well. I only got a day and a half out of it, before it went down for good. It is just a trick to get you and your vehicle off of the road or possibly a dangerous situation after a break down. My fuel pump needed replaced.
Old 08-28-2007, 08:17 AM
Thanks for all your advice. I've been reading other posts as well and it seems that I have been pretty lucky that my first fuel pump has lasted over 100,000 miles. Others have reported to have replaced it more often.
Old 08-30-2007, 08:29 AM
Well, just replaced fuel pump with a brand new AC Delco MU13 and even though the old one didnt give me any new problems, I did decide to go ahead and replace it since it had been 5 years and 100,000 mile since I replaced the old one. I must say that I have not noticed much of a difference, but still I feel that the peace of mind of knowing that I have a brand new pump is good enough.
I paid $231 for the original MU13 at rockauto.com! After reading the forums and all of your advice I thought it be best to spend a couple more buck to get the better part.
Thanks all!
