Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 08-27-2007, 08:33 AM
Uncle1957's Avatar
Uncle1957 Uncle1957 is offline
Drivers Window Sluggish or Gets Stuck Half Way Up
Hi:
My drivers side window slows or gets stuck half way up. If I grab the window and pull up as the motor is running it will make it past. Sometimes it slows then makes it past on its own.
Does that sound like a bad regulator or a weak motor?
Gord
Old 08-28-2007, 08:15 AM
rkvons's Avatar
rkvons rkvons is offline
Re: Drivers Window Sluggish or Gets Stuck Half Way Up
I've had to tear into my driver's side door a couple of years ago. The window rides in a track and is pushed up by the motor lifting an arm that the window is attached to. The problem I found with mine is that the front part of the track(not adjustable) is bent from the stress and is towards the front of the vehicle. When the window is made to go up, it shifts forward in this slop and gets stuck. If you notice the top of the window towards the rear of the vehicle coming away from the track as you are raising it, you probably have the same problem. Grab the top of the window and hold it towards the rear of the vehicle as you raise it and it goes up nicely. The only way I know of to fix it is to bend the metal back inside the door, but then it will be weaker and will most likely just bend back. If someone, (a kid) ran up and jumped up and hung their weight on the window when it was partially up, it would bend the front guide and mess things up. Or maybe it just from use. If you don't have the problems as described above, you can probably open up the door and grease the moving parts and get another couple of years out of it.
Old 08-28-2007, 09:32 AM
Uncle1957's Avatar
I will take a look in mine. If the track bent you could put a shim under it straightening it. I did that with my old Lincoln TC.
Thanks for the advise..
Gord
Old 08-28-2007, 12:22 PM
sirjonas sirjonas is offline
did you get the window fixed? was it a bent track as i have the same problem with mine. although it got noticably better after i removed the window to tint it and then put it back in.
Old 08-28-2007, 12:51 PM
Uncle1957's Avatar
No not yet. Saw an old post advising to lower window and empty a can of silicoln lubricant split between the two tracks am going to try that before disassembling the door.
Will keep you posted.
Gord
Old 08-28-2007, 02:41 PM
ok thanks
Old 08-30-2007, 04:33 PM
Uncle1957's Avatar
The Silicoln Lube did the trick.
Will the window all the way down spray liberally down in the rear track. Raise the window half way repeat in the front track. It has worked flawless for 3 days now.
Gord
ok thanks
Old 08-30-2007, 05:21 PM
ok i may have to try that. What brand of spray did you use?
Old 08-30-2007, 11:10 PM
Uncle1957's Avatar
It is Auto Sense Brand.....
But probably any good Silicoln Lubricant Spray will work.
Gord
Old 09-12-2007, 12:38 PM
What tracks did you use the lube on? the ones that the actual window rides on or the plastic ones that the rollars roll on?
Old 09-14-2007, 08:40 AM
Uncle1957's Avatar
I lowered the window and let loose on either side. But I would do both. It has been a couple weeks at least window is still smooth as silk in it's movement.
Gord
Old 07-02-2013, 02:01 PM
SteveinBelo SteveinBelo is offline
I used graphite spray in the window tracks and it worked great. I had this problem on two windows and had disassembled one door panel but the spray worked great on both. Thanks
