Old 08-27-2007, 06:32 AM
bigjohnsons34 bigjohnsons34 is offline
rear end
hi i have a 95 blazer and i noticed the the cover on my rear end is rusted, and i noticed the the gear oil is leaking through. it looks easy to replace but i was wondering how to refill it, i noticed that there a 2 ft tube that comes off the top of the rear end and goes over the frame with a plug on the end... is this how i would refill it, how do i know how much oil to put in and what type of gear oil do i use... thanks
Old 08-27-2007, 08:46 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: rear end
80/90 GL5 gear oil for regular rear ends.
Look on the front side of it and you will see a fill and check level pipe plug.
Fill it up till it runs out.
For towing or and some newer rear ends the use synthetic gear lube.
If it is one of them it should have a tag where the filler plug is and check owners manual for specs.
MT
Old 08-27-2007, 10:18 AM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: rear end
I'll just add a little more of what essentially MT said. The fill hole is on the front right,(passenger side of the differential). Take your time and you will eventually get it to come off. They can be difficult to get off sometimes.
Old 08-27-2007, 11:26 AM
scholzee scholzee is offline
Re: rear end
To add a little more the plug will have a square recess in it, use a 3/8" extension on a ratcht to remove. Its like a giant set screw but instead of an allen wrench you use the square end of a ractcht extension to get it out. With the truck reasonably level put fuild in the hole until it leaks out while you are not adding any more and reinstall the plug.
