Old 08-27-2007, 02:35 AM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
Laptop Question error code
Alright my dell inspiron laptop will not load. It gets to the windows xp loading screen and then i get a blue screen. saying
Stop:0x00000024 (0x001902FE, 0xF8B3580C, 0xF8B35508, 0XF852D1FC)
NTFS.SYS address F852D1FC Base at F8520000 Datestamp 41107eea
Anyone have any idea what this means?
Pictures of the Truck
Old 08-27-2007, 04:00 AM
Re: Laptop Question error code
Oh, i think i should also mention that i cannot boot from the system cd or attempt to reinstall the OS
Old 08-27-2007, 10:20 AM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
The NTFS file system is corrupt. That actual system file may be corrupt, bad data somewhere, or SCSI and/or IDE drivers are corrupted. Run a diskcheck if possible to see if it will repair the problem. Did you install any new software prior to this?
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
Old 08-27-2007, 01:03 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
I find it hard to believe that an operating system file being corrupt is limiting you from booting to a system disc. Make sure in your BIOS that under the boot menu, CD is listed above the hard drive. Then also make sure you hit a key when it asks to boot to the CD drive.
After you get into the Win XP setup, go to the repair console. Run the command of "chkdsk" and let us know if you get anywhere with that or if it detects errors that are unfixable.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-27-2007, 03:57 PM
When i start the system with the XP disc in i can get to the menu to select install/repair but when i select either one i get that blue screen. Im not sure if its the same error codes but its the same blue screen.
Old 08-27-2007, 04:01 PM
any idea how to get into the check disc option? I remember getting into it before but the battery died so i couldnt do it. I've got the power cord now so if i can get back in there i can run the tests.
Old 08-27-2007, 06:18 PM
Alright so i just spent an hour chatting with "dell tech support" Using the error codes i listed they claim its a harddrive fault and i need to replace that.
My warranty expired in 2006 so i would have to pay. Im working on trying to get them to fix it for free though. Ill comment again when i have more information on the topic
Old 08-27-2007, 08:08 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
References:
http://support.microsoft.com/kb/228888
http://www.techspot.com/vb/all/windo...sys-Error.html
http://techrepublic.com.com/5208-623...218843&start=0
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 08-27-2007, 08:21 PM
How can i format the drive if i cant load anything? Is there a way to do it before it tried to load XP? Or is the harddrive just shot??
Old 08-27-2007, 09:07 PM
To format, you'd have to do it either through the command prompt or hook the laptop up to another machine. And I would absolutely, positively, make sure the problem is nothing else but the hard drive and a format is the only solution. I've learned this the hard way.
Old 08-27-2007, 09:34 PM
Well there is nothing on the laptop im worried about losing. Im just trying to get it working so i can sell it. I would rather have it working so i can get more for it.
Old 08-27-2007, 09:46 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Why not buy a new hard disk, and put the existing disk in an external USB2 case, to be used as additional storage.
You can install Windows on the new disk, and it'll be easy to format the existing one - just plug it into another computer for format.
Old 08-27-2007, 09:53 PM
Well im trying to sell it so i want to avoid putting money into it if i can. If there is a way i can format the hard drive thats in there i would like to do that. Otherwise ill probably end up listing it on ebay with the faults.
Old 08-27-2007, 09:55 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
OK, just get an external 2.5" USB2.0 case. They're about $10, and will allow you to plug the drive into another computer and format it.
Old 08-27-2007, 09:58 PM
How hard is it to remove the drive from the laptop? and whats the risk that i could mess something up? Im somewhat good with taking stuff apart and putting it back together the right way.
