Old 08-26-2007, 06:25 PM
gserve gserve is offline
coolant problems
2000 Chevy Blazer. I have recently been loosing coolant through the overflow. Does this mean that I should replace the radiator cap? The coolant temp is fine. Also the cap I have is plastic and says closed system and is rated at 15 lbs. I looked up the cap on the Napa web site and they list a 16lb cap.Is it alright to use a higher rated cap? Any input please. Thanks
Old 08-27-2007, 09:21 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: coolant problems
Is the coolant coming out the top of overflow tank or is there a hole in it or is the hose leaking?
Has the coolant ever been changed?
Yes get a good rad cap first thing.
Use what the book calls for on the lb of cap.
MT
Old 08-27-2007, 06:25 PM
The coolant comes from the overflow tube. The coolant hasn't been changed since I have owned it. Is it OK to use a 16lb instead of a 15lb cap?
Old 08-27-2007, 06:37 PM
MT-2500's Avatar
AF - Advisor
Use what Oem chev parts specs call for.
If the coolant has not been changed it may be a good time to change it.
M
MT
