Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-26-2007, 05:53 PM
Gsst98's Avatar
Gsst98 Gsst98 is offline
Send a message via AIM to Gsst98
Question Rear brakes making noise
Today I changed my rear old rotors and pads for new ones on my 98 GST. I started to drive around to break in the pads but there is a noise that sounds like the pads are scratching the rotor when im driving when im not pressing the brake. IS this because the pads and rotor are still not worn in or is it a problem with the e-brake or something totaly different? thanks
Old 08-26-2007, 06:52 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Rear brakes making noise
It will go away in a few days.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-30-2007, 08:23 AM
Gsst98's Avatar
alright i found that the nosie is coming from the e-brake ive drivin over 600 miles and it still is making noise and the e-brake wont hold the car when on a hill is there a way to adjust the tension in the e-brake?
Old 08-30-2007, 08:56 AM
Holset powered 420a
Yes you can adjust it, you might want to adjust the ebrake pads so they dont rub anymore, you have to pull the back wheels off. Then try tightening the cable inside the car, just pull the cup holders out and you should be able to get to it from there. That should take the slack out the cable and it should hold better.
Other than that the pads may be glazed over from heat.
98 Eclipse GS Turbo
2001 BMW 325i - DD
