Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 08-26-2007, 01:57 PM
vandok13's Avatar
vandok13 vandok13 is offline
Best oil?
What would be the best weight and type of oil for my 1988 22R-E 4runner. 261 000 km????
Old 08-27-2007, 10:40 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Best oil?
I would use 5W30 all year around unless you live really north. Then 0W30 or 0W20 synthetic.
(considering you live in Canada)
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 08-29-2007, 07:39 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Best oil?
I'd suggest something a little heavier for the summer, like 10W30 or even 20W40 if it gets hot.
Synthetic oil is not normally suggested for high mileage (worn) engines.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 09-20-2007, 05:45 AM
xthirdimpact xthirdimpact is offline
Re: Best oil?
On the topic of oil choices / alternatives, ive been going to the dealer for the oil changes and they use their "synthetic blend" that they claimed to have switched over to a few years back.
Any of you Toyota pro's have an opinion on this? Is full synthetic better? Worse? Opinions?
Old 09-20-2007, 08:50 PM
Brian R.'s Avatar
Resident Chemist
Re: Best oil?
Synthetic oil is certainly superior to dino oil. However, whether it is necessary to run synthetic for your engine to last longer than with dino oil is another story. IMO, you should use synthetic only when it is clearly superior to dino oil. When is that?
When you have an engine that really gets oil hot or contaminates oil more than normal (for example, If you have a turbo, or in the Toyota engines that are known to have sludging problems).
When you drive short distances and don't heat up your oil enough, or heat it long enough to vaporize contaminants.
When you don't change your oil frequently because of various reasons.
There may be other times, but I don't remember them all.
Synthetic oil is clearly superior to dino oil in oxidation resistance.
Synthetic oil is clearly inferior to dino oil in cost.
If you want alot of data on the subject, go to http://theoildrop.server101.com/forums/ubbthreads.php
