Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-26-2007, 12:49 PM
rob's garage rob's garage is offline
Question change top or die
should i die the top or just strip it down and paint it what is less exspencive
Old 08-26-2007, 01:26 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: change top or die
What are you talking about? We're not psychics here!
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-26-2007, 01:47 PM
mike561 mike561 is offline
you mean DYE the top
2006 Chevy Cobalt LS
Old 08-26-2007, 05:32 PM
dye the top or not
Old 08-26-2007, 05:33 PM
yes will that be better
Old 08-26-2007, 05:41 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
How old is the vehicle and how is the metal underneath the top? Are there any rips/tears in it, how is the overall condition of the top? Where I live the option would be to strip off the top, do any necessary bodywork to remove the rust/holes and then paint the metal. But that is NY and is somewhat typical, where you are the conditions might be totally different and the top could be in better shape.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 08-26-2007, 06:11 PM
the top is in good shape no rips at all thats not the problem one or the other will be done witch will be chepest
Old 08-26-2007, 06:35 PM
Well, for starters, this is how you worded it:
Do you mean taking the top off completely and painting the metal underneath, when you say "strip it down and paint it"?
The reason I posted above is that if you go that route you need to make sure there is no rust or holes that are sometime evident when you remove such top due to moisture. If there is then that will add to any costs. In my experiences, I've always had to remove the tops in my vehicles because of their poor conditions, then sand, apply filler and then paint it. If your not concerned about that and the top is still in good condition, then dyeing it might be cheaper, and less labor intensive,(that is if you are going with the same color or darker.)
