Old 08-26-2007, 07:11 AM
2003 Ford Taurus 2003 Ford Taurus is offline
2003 Taurus - Unknow Engine Idle Noise
Ford 2003 Taurus:
Background:
52,000 miles
Regular maintenance
New tensioner pulley & belt
Situation:
An unidentifiable noise is generated while engine is at idle. The sound does not seem to be originating from the accessory drive (Serpentine belt & tensioner). The tensioner pulley and belt were replaced with no change in situation.
Noise: Is an itermittent squeaking sound which may be coming from the topside/backside of the engine. The sound is inaudible when rpms are increased:
* There may be a technical service bulletin (#0311) for this problem, but I have been unable to access.
* Are there any blowers etc within the air intake or fuel injection system?
Last, any assistance would be most appreciated. Serving in Germany with US military with access to a limited capability base service garage.
Thank you
Old 08-26-2007, 07:51 AM
taillight taillight is offline
Re: 2003 Taurus - Unknow Engine Idle Noise
Maybe alternator bearings ?
Old 08-26-2007, 01:05 PM
UncleBob UncleBob is offline
AF -Advisor
remove the serp belt, see if the noise goes away. That'll rule out all of the accessories
otherwise, get a stethoscope....best tool for hunting down noises
DOHC or OHV?
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 08-31-2007, 06:20 PM
higgimonster's Avatar
higgimonster higgimonster is offline
I found a tsb about a vibration from the cooling fans but it only occurred when AC is on and outside temp is 80F/27C or above.
but that would be the front of the engine
tsb# 03-11-1
the other one i found is a ticking sound coming from the left bank camshaft. use a long screwdriver and check near cyl 6 for the ticking sound. The left bank is the one on the right when looking at the acc belt. cyl 6 is either closer to the acc belt or further away (yeah I can't remember how they're numbered)
tsb# 04-20-8
I know neither of these are squeaks but these are the tsb's I found. good luck.
one of the things i do is take a can of power lube and start spraying the pulley's of the accesories, not where the belt hits but behind where they are on their bearings.
Promoter of the one line signature.
Old 09-10-2013, 11:38 PM
jjsikes jjsikes is offline
cam shaft positioning sensor sincronizer
Old 09-16-2013, 10:43 PM
vgames33 vgames33 is offline
Ford V6s come in all the time for a random squeek. The cam synchro usually fixes it.
EDIT: Just noticed how old this thread is. Let it die.
