Old 11-17-2002, 07:19 PM
chris26969 chris26969 is offline
AutoMatic Tranny
My tranny grinds at 20mph , whats the deal.
Old 11-17-2002, 07:49 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: AutoMatic Tranny
When was the last time you had the fluid changed?
Old 11-17-2002, 08:03 PM
never , i got the car like a month and a half ago . Im new to my car , so how do i change the tranny fluid?
Old 11-17-2002, 10:59 PM
Mirt3 Mirt3 is offline
Send a message via AIM to Mirt3
i dont know how to do it but the dillshmacks at jiffy lube can do it for like 75...if they can do it, id assume its pretty easy...unless they use special tools and such.
-Mike
Old 11-19-2002, 12:55 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
i never heard of an auto grinding, weird.
its easy to change the filter. just unbolt the drain pan, unbolt the filter. bolt on hte new filter, bolt back on the tranny pan. make sure you torque down to the right torque setting. fill it back up
but the jiffy lube guys also flush the torque converter i believe, thats alittle harder to do. if you just take off the pan and put it back on, theres still all the old tranny fluid in the torque converter.
to flush the toruq converter, you need to take off the trans cooler lines, one line flows tranny fluid and the other sucks in tranny fluid. run the car and as trnany fluid comes out, put tranny fluid back in. and do this till you add about 4 quarts, then stop put the lines back on. then check the tranny fluid level. oh you do this after you replace the filter
Old 11-19-2002, 01:22 AM
emerge's Avatar
emerge emerge is offline
Send a message via AIM to emerge Send a message via Yahoo to emerge
my auto did that too... it's actually just started doing it lately. someone suggested oil to me but im goin to get the tranny fluid changed...
Stephen Gladney
Original PH Member
EJ8 Civic | AIM: nxzo | www.rtek.org
Old 11-19-2002, 04:32 PM
well it doesnt only grind at 20 mph , it kicks from gear to gear . ya know what i mean , like a small kick .whats the deal
Old 11-19-2002, 05:37 PM
moondawgy's Avatar
moondawgy moondawgy is offline
check your tranny stick and see if it's chewed up, if it is, u put the stick back on an angle and the stick is being grinded........it happens as i've seen it alot of time.........u would need to flush out the fluid......
honda got a mesh wire inside the transmission, i'm pretty sure they dont actually have a filter. all u really need is to drain and fill, u can just run some fluid thru it if u want to flush...........
u can probably do it yourself in like 20 min, it's not really alot of work (just 1 plug), plus it's alot cheaper.
try using some slick 50 in ur tranny as i found it helped alot
Old 11-24-2002, 11:33 PM
emerge's Avatar
go outside right now and check your transmission fluid! if you don't know where the dipstick is, look it up in your owner's manual. mine had the same problem and i got mine changed. but i waited so long to change it that i had to get a 'power flush' and that costed me 150$, but i still have my transmission :o
Stephen Gladney
Original PH Member
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
