Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-26-2007, 02:33 AM
Rugermk2 Rugermk2 is offline
1993 Camaro Z28 Noise?
Hi,
I recently bought this camaro with 117,000 miles. It makes a knocking/clunk noise at speeds below 15mph. The noise sounds like it is coming from the drivers side front wheel while im inside the car, and driving it. I just replaced the outer tie rod ends today, as they were wore pretty bad, but still makes the noise. All the lug nuts are tight, and the wheel bearing didn't seem to have any play, and turns freely. Any ideas on what could be wrong? Thanks everyone.
Rugermk2
Old 08-26-2007, 10:35 PM
abaird abaird is offline
Re: 1993 Camaro Z28 Noise?
I'd be looking at ball joints, also check that the sway bar connections are good and tight and that the bushings are all still there. Don't forget the struts too, with that mileage those are some pretty typical things to look for.
2009 Silverado 1500
2002 Camaro Z28(rebuilder)
2005 Yamaha GP1300R
