Old 11-17-2002, 05:49 PM
HammerGWF HammerGWF is offline
Send a message via AIM to HammerGWF
1995 Honda Civic EX question
I just replaced the fulel filter and the car is still actinlike its not getting gas sometimes, its studdering, im not sureif the fuel injectors need cleaning or its the fuel pump any help would be greatly appreciated
Old 11-17-2002, 10:20 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
yeah, if you just replaced the fuel filter, then I think it would be the fuel pump. Maybe a clogged line somewhere, but check the fuel pump first.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 11-17-2002, 10:21 PM
b16a3sol b16a3sol is offline
are you sure its not an ignition problem?
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 11-18-2002, 12:28 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
could always check fuel pressure...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 11-18-2002, 01:40 AM
are your tires inflated properly?
2000 BMW 323IT
1954 Ford F100
Old 11-19-2002, 12:57 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Yea check your fuel pressure or run a higher octane.Then as stated above check ignition.then if all else fails like kicker said check tire pressure hahahaha
Old 11-19-2002, 06:56 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
i would get some fuel injection cleaner because its really cheap and try and use that and see if you get soem results from that. if that doesnt work then i would pull out each spark plug and make sure its ok adn its gapped properly. you could also try and replace the rotor, ignition coil, distributor cap, spark plug wires. even if this isnt a problem, if you havent done it in a long time, its due for a tune up.
Old 11-21-2002, 04:40 PM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
oh yea....and for all of you that dont know Allen (hammergwf) is a weiner that knows nothing about cars, although i give him props on installing the fuel filter himself.....good job ya jolly little retard!
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
