Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-25-2007, 07:56 PM
garydh2000 garydh2000 is offline
Out Went The Lights
All of my dash lights were working yesterday and then tonight I start the Rodeo and turn the lights on and no dash lights at all !!
I looked through my Haynes manual and still do not have clue how to diagnose ands fix.
Anybody have any experience with this problem.
Thanks,
Gary
Old 08-25-2007, 09:34 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Out Went The Lights
did you turn the knob?
Check the fuses?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 08-26-2007, 01:34 AM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Definatly start with the fuses. When you turn on the lights also check that the corner and tail lights come on. If they do then I'd suspect the dimmer switch on the dash or something after it. If not then its a problem with the ciruit before the dimmer switch.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 08-26-2007, 09:17 AM
My Rodeo is a 1996. There is a chart on top of the fuse box but I can't seem to be able identify what fuse is for the dash lights.
Does anyone else know what fuse is for the dash lights?
Old 08-26-2007, 11:21 AM
rodeo157 rodeo157 is offline
sounds like you under the hood. the fuse for that is under dash. opend the little door and it says on the inside of the cover
95 Rodeo 3.2L v6 5spd 4wd, 31" tires, toyota rims (for now)
Old 08-26-2007, 06:45 PM
Gizmo,
The tail lights are also out. I checked both fuse boxes and can't identify the ones for the dash lights. I checked both the vehicle owners manual and the Haynes repair manual.
Old 08-26-2007, 08:19 PM
teamrush42 teamrush42 is offline
Originally Posted by garydh2000
Gizmo,
i gots the same problem...all fuses are good - tail lights work and dummy lights work - just no dash/gauge lighting...AC control lighting dosent work either
Old 08-26-2007, 10:39 PM
trooperbc's Avatar
trooperbc trooperbc is offline
...The tail lights are also out. I checked both fuse boxes and can't identify the ones for the dash lights. I checked both the vehicle owners manual and the Haynes repair manual.
take a look at this thread and see if it helps.
http://www.automotiveforums.com/vbul...sh+lights+tail
you can also do your own search using the words 'dash lights tail' and you will get a ton of hits to wade through. the short story is they are all part of interconnected circuits.
both fuse boxes will have 'maps', the underhood one, and the one on the lower part of the dash panel, the map is on the swing down door.
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
