Old 08-25-2007, 06:14 PM
jfranklin jfranklin is offline
93 LeSabre transmission problems
Hi
My 93 LeSabre (96k) started making noise right around the transmission bell cover ( this noise ,a sort of buzzing/whistling, would change with gear changes and acceleration)
Soon after the tranny would not engage but if I turn the engine off and back on the tranny will engage for a while and then go back to nothing.
I'm going to drop the pan and see what surprises are in there
Is my tranny shot ?
Old 08-26-2007, 11:00 AM
maxwedge maxwedge is offline
A990 racer
Re: 93 LeSabre transmission problems
Most likely, you may find the filter clogged but that just points to internal component wear. Wait till it is apart, post back.
Old 08-28-2007, 01:55 PM
I dropped the tranny cover and found 96k miles worth of sludge on the bottom, also the magnet was thick with it but no metal fragments
So I put a new filter in and new fluid and it seems to run fine even better than when I bought it
But i'm still hearing a whistling weeze coming from the general area of the bell cover (drivers side)
Could a component in that general area be defected either inside the tranny or above where the air intake and hoses are ?
Should I post another thread about the whistling and wheezing the engine is making ?
Thank for the response !
Old 08-28-2007, 07:54 PM
A990 racer
Without actually hearing the nature of this noise on site it would be impossible to give any comprehensive advice, the trans could still be noisey, there are internal conditions in the chain sprockets that can cause this as well as internal line pressure issues.
Old 08-29-2007, 05:42 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
the sound you're hearing could be the torque converter or front pump assembly, but as Max stated, it's hard to diagnose without actually hearing it.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-29-2007, 11:05 AM
I could record the sound and send it as a mp3 attachment
i just need an e mail to send it to
Old 08-29-2007, 03:36 PM
A990 racer
Lightbulb Re: 93 LeSabre transmission problems
This won't work, have a trans shop or tech listen to it and see what they say, at some point you will need professional intervention here.
