Old 07-02-2007, 09:46 AM
asav220 asav220 is offline
DRL problem
I have a 96 blazer and when my daytime lights are on they are fine, but when I activate my night driving lights the DRL do not shut off and start making a ticking from the relay center box in the right glove box. Especially when I apply the brake
Any Advice?
Old 07-02-2007, 09:50 AM
DRL problem! Help!
I have a 96 blazer, and when my daytime lights are on they are fine, but when I activate my night driving lights the DRL do not shut off and start making a ticking from the relay center box in the right glove box. Especially when I apply the brake
Any Advice?
Old 07-02-2007, 01:49 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: DRL problem! Help!
In my '97 manual.....
There are 3 relays, left to right...Fuel Pump Relay, Horn Relay & Daytime Running Lamp Relay. Swap the middle & right relays and see if the horn works and your daytime running light problems still exists.
Old 07-02-2007, 08:27 PM
Day Running Lights Ticking
Help!
My day running lights work fine until the night driving lights are engaged.
The DRL flicker especially when the brake pedal is pressed.
Also making a ticking sound somewhere around the relay center in the glove box.
What should I do?
Old 07-02-2007, 08:35 PM
I did the switch and the problem is still there, annoying as ever
Old 07-03-2007, 10:14 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: DRL problem
Test or switch relays and have a look in the body control PCM.
If any body codes post back code no.
MT
MT
Old 07-03-2007, 11:24 AM
MT-2500's Avatar
AF - Advisor
Get intomthe body computer and check for body codes.
Post back any codes.
MT
Old 07-06-2007, 10:48 AM
I did not get any codes
Old 07-06-2007, 10:49 AM
Re: DRL problem
No codes came off...
Old 07-06-2007, 11:49 AM
MT-2500's Avatar
AF - Advisor
Originally Posted by asav220
Get in to the body computer and check for body codes.
Did the body PCM communicate with the scanner?
I do not have any info on the DRL lights for a 96.
Are they add on or factory OEM.
Any add on remote start or anti theft stuff on there?
I would suggest a good factory service manual or a.
http://www.alldata.com/products/diy/index.html
MT
Old 07-07-2007, 05:44 PM
It is all factory, and the scanner really did not talk to the computer. Maybe I just have a bad computer?
Old 08-25-2007, 03:46 PM
96 blazer schematics
I just bought a 96 blazer and some one did a hokey job of putting power back into my motorized seat and I took the wire out that was connected to an orange wire underneath the cigarette lighter but now the seats dont work yet I have the correct wires hooked up.
I NEED HELP!!
Old 08-25-2007, 04:52 PM
Angry NEED 96 blazer schematics
Just bought a 96 blazer, need schematics because someone had the orange wire to the power seats cut and than ran another orange hot wire from the dash board to the seats. I took that hokey wire out and re-hooked up the orange hot wire to the power seats, and I've tore up the carpet to follow the wire but it looks like it should work but nothing happens. Any ideas?
Old 08-25-2007, 04:54 PM
Angry Ticking from glove box when night time lights are activated
Just bought a 96 blazer and didnt notice that the glove box ticks when the night time lights are on but it does. Its coming from one of the three relay switches in the glove box but I have replaced them all but nothing has worked. Any Suggestions
Old 08-25-2007, 06:13 PM
Angry Power Seats hooked up but wont work!!
I have a 96 blazer with power seats, well it did have power seats but the orange wire running to the seat motors was cut so someone ran another wire from a different hot source to that seat well I took that cheap splice they did off and reconnected the cut orange wire from underneath the seat back up and now the seats are still not getting any power. I need help bad!!!
