Old 08-25-2007, 05:24 PM
kaptin keg kaptin keg is offline
is Visonik a good brand?
i have a 1995 gmc jimmy all stock and i have ordered off of sonicelectronix.com a amp, box, and sub deal and the brand is visonik there 2 12 inch subs and this is the amps keypoints
  • Amplifer Power Output:
    • Peak: 700 watts x 1 channel, 4 ohms bridged
    • RMS: 350 watts x 1 channel, 4 ohms bridged
  • THD: <1%
  • Built-in low-pass filter
  • Power/ Protection LED
  • RCA Line Inputs & Outputs
  • Thermal / Short / Overload Protection Circuitry
  • High level input allows system to hookup to your factory radio using speaker wire connections
  • Variable HP / LP Crossover
  • Adjustable Input Sensitivity
  • Full MOSFET Circuitry
  • Authorized Internet Dealer
  • 1-year Manufacturer's warranty
and here are the subs and box keypoints
Subwoofers Power Handling:
  • Peak: 900 watts total
  • RMS: 450 watts total
Dual 12" Loaded Bass Enclosure
Computer Engineered Woofer Enclosure
Digitally Computer Tuned Subwoofer for this Particular Enclosure
Chrome Sub Design
Complete Sealed and Pressure Tested
Heavy Duty Aviation Carpet
Heavy Duty Lock Terminals
Heavy Duty Poly Coated Pulp Cone
Medium Density Fiberboard Construction
Dimensions: 26.5"W x 13.5"H x 9.5"D
1-year Manufacturer's warranty (Subwoofers only)
is this a good setup for my jimmy?
and i ordered dash and new door speakers for the jimmy and a dual reciever is there going to be enough power for replacing my stock speakers with the new speakers. The dual reciever it has 220 wats capability or do i need to get it to my amp in someway?
i need help
Old 08-25-2007, 05:43 PM
nicks84 nicks84 is offline
Re: is Visonik a good brand?
  • THD: <1%
Chrome Sub Design
i need help
As for you set up, its fine, meaning you have the right ideal. The question about the HU being able to power the speakers, it depends what speakers they are. Brand/ size ?
Visonek is CRAP , and no, Im not one of those jack asses that biases them because there not name brand, there just not very good. However, as long as you have them in a good box, they will sound fine. NOT anything to compete with, but will suffice, just be sure to pet them in a well build and designed to spec box. Dual, pretty much the same boat, both, are about as cheap as it gets. But, personally, Id rather have those then standard stock equipment, if that matters at all. Hope this helps a little.
Old 08-25-2007, 05:50 PM
thanks for the post i dont really need anything special im only 15 and limited on money but thanks for the help
Old 08-25-2007, 06:48 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
I feel your pain on that one .... when I was 15-16 whatever, I didn't have much money either.
Old 08-25-2007, 10:56 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Your setup should be all right. Its sucks that you have to be stuck with lower quality stuff though. Usually aftermarket speakers will sound better with a separate, dedicated amp since there is a lot more power, but the deck amp will be fine.
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
Old 08-26-2007, 10:59 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Get what you can your not trying to set records so screw it.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 08-26-2007, 11:17 PM
I hear ya loud and clear I have 2 car, one I went lavish in, the other just has plane Jane crap, but it sounds alot better than the stock
I couldnt agree more. But hell, even a stock amp will be fine for those (excluding the sub)
Old 09-08-2007, 01:27 PM
ISmellRubber's Avatar
ISmellRubber ISmellRubber is offline
I installed a visonic 12" matched with a 250 watt amp(mono block 4ohm) I put it in a fiberglass box I formed to my wife's 97 blazer rear compartment. It was not the best sound I have ever heard,but with the budget I used for HER stereo this worked just fine. Keep in mind I am one of those guys that is bias to certain brands however it was a good investment for under $100. If you want a good single sub for under a $100 try an audiobahn sub tube http://www.sonicelectronix.com/item_...hn+ATB12T.html# this has satisfied my personal need with a pair in my Cadillic STS with a 2x250 Wolfenhage amp I brought back with me from germany before they hit the us and got bought out by rockford.
