Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 08-25-2007, 04:00 PM
cliftong4192 cliftong4192 is offline
Ac Problem
New Problem Was Charging The A/c And The Compressor Clicks On And Off And The A/c Is Not Get Cold Also I Did The Conversion Kit But The Fittings Blow Outward I Think I Did Something Wrong Please Help Thanks And By The Way The Battery Was Draining Because I Needed To Replace The Neg Battery Cable Thanks For All The Help
Old 08-25-2007, 10:29 PM
Towncar's Avatar
Towncar Towncar is offline
Re: Ac Problem
Originally Posted by cliftong4192
... And By The Way The Battery Was Draining Because I Needed To Replace The Neg Battery Cable...
What? I can see how a battery might not charge sufficiently with a negative cable problem, but draining??
The only way a negative cable can drain a battery is if it was shorted to the positive cable.
Somethings fishy.
-Steven
1996 Town Car, Cartier
Old 08-26-2007, 04:13 PM
Re: Ac Problem
two questions the a/c was converted to 134 and now the compressor only comes on for a few seconds at a time instead of running like it should and when i step on the gas the battery light on the message board the levels are all the way up and the battery light starts to blink which makes that annoying ding sound please advise thanks cliff
