Old 08-25-2007, 12:22 PM
Josue Josue is offline
94 pa high idle,lack of power.
I would really appreciate if anybody could help out. I just bought this vehicle it's idling at 2000 rpm then drops to 700 rpm in gear also chokes when I accelerate,can't drive it on road,replaced plugs, maf sensor,fuel filter and 1 corroded coil tower ,fuel pressure is 45 psi.
Old 08-25-2007, 05:13 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 94 pa high idle,lack of power.
You need to find someone who has an OBD 1.5 capable scanner and give us the TPS, EGR & MAP sensor readings and any set codes. Is this car an Ultra, or standard PA? High idle, may be any of the above.
