Old 11-17-2002, 01:32 PM
onetrueshyguy onetrueshyguy is offline
Help! brake lights on
hi i have a problem..on the dashboard my ebrake lights are always on even though i realeased my ebrakes
does anyone know what the problem could b? thanks
Old 11-17-2002, 09:56 PM
b16a3sol b16a3sol is offline
its probably just the switch at the handle getting stuck. take off the center console that holds the e-brake handle and look for the switch that tells the car the brake is on. play with it for a little while and see if its broken or not. if it is, then replace it and all should be well. if its not, then you have a connection occuring somewhere else. just track it down and you are done.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 11-17-2002, 10:00 PM
thx
but i heard it also be b a problem with the brake system
"Question
What do the brake warning lights mean in my car?
Answer
Most cars have one or two brake warning lights on the dashboard. When you first start your car, all of the lights on the dashboard should light up. This is the bulb check; they should go out in a few seconds. If a light doesn't go out, then your car is alerting you of a problem. If a light does not light during the bulb check, it tells you that you need to replace the bulb.
Your car illuminates the BRAKE light (see below) to indicate one of two things:
that your emergency brake is on. Release it to solve the problem.
that you have lost brake pressure in half of the brake system (see How a Combination Valve Works for details).
Brake warning light
In the second case, you should slowly and calmly pull over and stop. If the brake system has completely failed, you will have to use the emergency brake for braking. If the light stays on, it means that the pressure on one side of the brake system is lower than on the other.
There are a couple reasons this could happen:
There could be a leak in one part of the system, making it impossible to hold pressure
The hydraulic fluid could be low
In either case, your braking performance will be impaired and you should have the car repaired before driving it again. "
Old 11-20-2002, 12:06 AM
as far as i know, braking systems work by having 2 tires at oppositte corners of the car share the same pressure. this means that the car wont pull too hard if you do lose pressure in half of it. you could jack up each tire, spin it, then have someone press the brake. if it stops all of the tires, then you know its not that. the other thing to try is jacking up the back end and check to see if the e-brake works by doing the same thing. if your brakes still work, then it could be the switch. if you have to push the pedal really hard to get them to work, then i would think there is a problem that needs to be addressed. check to see if you have fluid in there also. if all else fails, take it in, seeing as how brakes are kind of important when you are driving.
Old 11-20-2002, 09:46 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
the ebrake light on our cars is a warning light telling you its time to replace the pads, they have worn down to where the sensor gets tripped.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 11-20-2002, 01:36 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
what, the light comes on when the brake pads are low. i never heard of that before. ive worked on brakes from 5th gens and 6th gens, and there arent any sensors on the caliper or the drums.
i think the light would only stay on if:
1. the switch is broken or something to that effect
2. pressure lost in the system. if you think its leaking, go under the car and look for leaks. idk how old your car is but check the rear drum wheel cylinders and all the brake hoses
3. maybe your brake fluid resevoir in low in brake fluid.
Old 11-20-2002, 05:37 PM
thanks
but in the worst case scenario how much would i b spending to get it fixed
Old 11-21-2002, 01:58 PM
depends on the problem that needs to be fixed. you could just need to buy some brake fluid. you could also need to have new brake lines run, in which case i would suggest upgrading to steel braded. you could need a gasket replaced on your master cylinder, or need the whole thing replaced. call the place you would have the work done at and get some prices. or take it in and have them tell you whats wrong and how much it will cost.
Old 11-22-2002, 12:19 AM
crxlvr's Avatar
i know for a fact that when the pads are low on my crx the ebrake light will stay on.
so i think you just need new pads.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 11-22-2002, 10:50 AM
but is 50% brake pads remaining okay or do i need replacement?
is it hard to fix the master cyclinder yourself?
Old 11-24-2002, 05:45 AM
Freeman Freeman is offline
Originally posted by onetrueshyguy
thanks
This happened to my mother's Toyota Celica. The brake light stayed
on for like a year+ before the car became a "suicide machine". But
when I first noticed it, and informed her, she was unconcerned about
it. Well, long story short, it cost her roughly $650.00 to fix it. But
she took it to Goodyear, so....
PS That brake pad sensor crap is CRAP! Even with ABS, I've
never heard of that shit.
Old 11-24-2002, 06:33 PM
crxlvr's Avatar
before you go claiming its crap, learn from someone who has experience, im a certified mechanic and the sensors on the pads will trip that light to stay on when it gets too low. manufacturers set the lights to come on earlier than deadly levels so you have a chance to fix it.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 11-24-2002, 07:59 PM
AnGeLoBBoy AnGeLoBBoy is offline
Send a message via AIM to AnGeLoBBoy
This has happened to me in my 90 Accord ... i checked everything and tore up the e-brake controls and the light was still on. I did the most common sense thing to do ... REFILL THE BRAKE FLUID. It might be the problem, it might not. But it's a suggestion
Old 11-25-2002, 07:18 PM
RoBoDEATH RoBoDEATH is offline
Send a message via AIM to RoBoDEATH Send a message via Yahoo to RoBoDEATH
could you just put some damn fluid in your brake resivour please? if it doesn't fix the problem it will get rid of the 99.99999999% chance that you are just low on fluid
1998 Honda Civic EX--Si Wing--Jackson Racing Supercharger--Enkei RP07 18inch Rims--Yokohama PARADA 215/35ZR/18's--K&N Filter--Hurst ShortShifter--DC Sport Header--Greddy Cat-Back Exhaust--DC Strut Tie Bar--Eibach Springs with Ground Control Coil Overs--Ingalls Rear Camber Kit Arms--Skunk2 Front Camber Kits--Panasonic DF88 CD Player--Two 1Fared Caps--Sony Xplod 800W Amp--SPL Series II 1200W Amp--Solo Baric 15--!!!!!SOLD!!!!!!!
2001 Honda S2000 NFR--HKS Hi-Power Duel Exhaust--NRG Hood Dampers
Old 11-25-2002, 07:36 PM
thank you guys for support okay i checked the fluids and it seems to be okay..and yeah i think the brake pads needs replacement..thanks
