Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 08-24-2007, 10:17 PM
oldrine oldrine is offline
Another 2001 Mitsubishi Galant Leak
Hi,
I have recently been using the AC regulalry while drivin my 2001 Galant. however recently i noticed some sound from the direction of passenger side glove compartment whenever i made a sharp turn, which sounded like collected water flowing to one side due to the inertia of the turn. Today i also noticed the same ominous sign of teh front passnger side carpet all soaked up and th ewater seemd to be commin from under the glove compartment
Please advice, thanx in advance
Lewis
Old 09-10-2007, 08:29 AM
Maryellen777 Maryellen777 is offline
Re: Another 2001 Mitsubishi Galant Leak
I have had the same problem, with a quote of 1,000.00+ to pull the dash and find the problem. I cut off my airconditioner in one of the hottest summers in history here. Now the car smells so musty I can hardly stand it. I had the tube cleared twice but still had the water problem. My e-mail is [email protected] if you have any suggestions for me.
Old 09-17-2007, 01:02 PM
Mitsitech001 Mitsitech001 is offline
Have you check if it's water or engine coolant(usually green stuff)? If it's water it means that the A/C drain hose may be blocked and causing condensated water to overflow inside the car....but if it's coolant, then the heater unit has got a leak.
Cheers
Old 11-27-2007, 07:41 PM
Inman Lanier Inman Lanier is offline
This is an old issue - search on the forum. The condensate drain line plugs up and needs to be cleaned. Not a big deal, but a little tight to get it done.
