Old 08-24-2007, 05:05 PM
javatrooper's Avatar
javatrooper javatrooper is offline
Lifter problem? How do I know? 1984-302
I have a 84 F150 with a 302 in it. I may have a bad lifter. How can I check it and can I replace the lifter without removing the head? Thanks
Old 08-25-2007, 02:09 AM
Torch Torch is offline
Re: Lifter problem? How do I know? 1984-302
Pull the valve covers off and watch the valves open and close, even better yet get a ruler next to the rocker arm and measure how far the valve is being pushed up, when you find the one that is bad undo the rocker and pull the push rod and a verify that it isn't bent.
If the push rod looks fine you will not (or should not) have to pull the head off but you will need to pull the intake manifold off. On most V-8 engines it is impossible to replace the lifters without pulling the intake manifold off.
An '84 is going to be loads of fun, there are wires and hoses everywhere but once you get down to the manifold it is just like any other V-8 manifold. Make sure you have new gaskets and sealer before you pull it off though.
Old 08-26-2007, 12:50 PM
Thanks for the tip. I'll post the results when I get it opened up.
Old 09-09-2007, 07:20 PM
rhandwor rhandwor is offline
Roll the push rod on a flat surface like glass. A bent one will be easy to spot.
Ford makes a slightly longer push rod if needed.
