Old 08-24-2007, 05:04 PM
goatdaddy77 goatdaddy77 is offline
Electrical! Gauges moving without keys in!
I have a 99 Intrigue GL, 3.8 liter. I drove this car to the bank and back, and only 25 or so minutes later I came back to find my car would do nothing and seemed dead! I immediately think its the battery, even though I had driven it only moments before. I check the battery to find I have good voltage. I get back in the care to notice my gauges moving up and down and the door bell making a clicking sound, I also notice that the keys arent even in the ignition while this is happening! I have pulled the dash from under the steering wheel, looking for any shorts in the wiring. I have read other threads about ignition problems and would like to at least attempt to remove and clean, but am not sure how to remove the ignition. If anyone has any helpful info on this problem or how to remove the ignition, it would be greatly appreciated
Old 08-25-2007, 01:07 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: Electrical! Gauges moving without keys in!
Ignition switch might definitely be a good place to start with this one.
http://www.automotiveforums.com/vbul...switch+removal
Theres how to get the little bugger out. Sometimes cleaning them just isnt enough, but I would clean before I would replace.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 08-26-2007, 12:45 PM
Thanks for the detailed removal of the ignition, it will be very helpful! Have you ever encountered any problems where a ground wire may be loose or rusty, causing electrical malfunctions?
Old 08-26-2007, 12:56 PM
LittleHoov's Avatar
That would be a possible solution as well. Check all the grounds you can find. Im honestly not sure where theyre all at.
There are universal grounding kits available that may or may not prove helpful.
Cleaning the ignition switch is free though, and you might notice a problem or two while doing that. Which is better than just throwing money around.
