Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-24-2007, 03:25 PM
paradrone paradrone is offline
Valve clearance question
95 talon tsi
I used an impact to get the crank pulley bolt off, later realised that I was spining the crank(very slowly) and not the cams.
The question is:
Is there only a valve damage risk at higher rpms? or did i probably mess some stuff up?
thanks.
Old 08-24-2007, 03:40 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: Valve clearance question
Originally Posted by paradrone
95 talon tsi
The question is:
thanks.
This is very difficult to tell because we don't know the timing position the cams are in. If the valves are open and you were able to turn the crank than you could have damaged the valves yes.
You have two options really. You can put everything back together and hope you can put the crank back at the proper timing without further damaging the valves. Then do a compression test, although you could damage your motor more by doing this.
Or you can remove the head and do a visual check.
1991 GSX 2.3 Stroker
Old 08-24-2007, 04:34 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Hate to break it to ya man, but you can't always tell with a visual check... I had a buddy who bent 4 valves and when he took them out they didn't even look bent. The only certain way to know is to take it to a pro who can pull vacuum on them and tell ya if any of them are bent or not...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 08-24-2007, 05:07 PM
defiancy's Avatar
Orly? I guess everytime I've bent a valve it's been bad enough to be seen -Cough- one time a few valves fell off.
Old 08-24-2007, 05:20 PM
inafogg inafogg is offline
u say you where taking crank pulley off. how come ?? if you were because of timing belt problems then why not just continue. put a new belt on there only $40 or so & you already started good luck
Old 08-24-2007, 05:24 PM
Uh dude... I think he was planning on doing that AFTER he gets the valve situation taken care of...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 08-24-2007, 05:31 PM
I'm doing cam gears, balance shaft elimination, crank pulley. I got it mostly back together.
I took off the crank gear yesterday(with the impact) and woke up in the middle of the night like OH F#@K!!!!!
thanks to everyone for all the help (didn't think about bent valves that you can't see with the naked eye, i will keep that in mind)
Old 08-24-2007, 06:35 PM
he didnt say why & to answer if valves are effected by rpms no they either clear the pistons or not. if you are turning crank freely(tight but with no hang ups) then you're proboly ok
Old 08-24-2007, 07:27 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
You can risk valve damage at any rpm, but if you were turning the crank slowly with an impact, I'm 99% sure you didn't bend the valves. The bolt would have broke loose before you bent any valves, so you're probably okay.
95 Talon TSI AWD
97 Eclipse GST
Old 08-25-2007, 06:54 PM
Got it back together, no spark to the 2 middle cylinders.
(checked plugs and wires, they are fine)
Any idea's
Did I damage cam sensor or would that kill all the spark?
thanks
(just realized i don't have the trigger plate from the back of the intake cam gear on, the new gear doesn't have a place for it? how did you guys do it?)
