Old 08-24-2007, 02:29 PM
metart321 metart321 is offline
how to get model to look like this?
I need help on the pattern circuled in red. How do you make the paint job like that?
Old 08-24-2007, 02:50 PM
drunken monkey's Avatar
Razor Sharp Twit
Re: how to get model to look like this?
Depends. On some kits, the texture is molded onto the plastic, in which case, the question should be; how can i get a good metallic finish.
Where there is no pre-molded texture, you can either try and replicate by shooting paint through mesh as they do for carbon fibre effect or use a textured foil in place of paint
i.e glue the foil onto the surface.
Some have used the foil from cigarette packets to good effect.
I think there's some textured foil intended for use as heat shielding that you can try.
You can also try and apply a similar texture to some Bare Metal Foil and use that.
AF's Guidelines
Read them.
Old 08-24-2007, 02:51 PM
builderweave's Avatar
builderweave builderweave is offline
I've seen people use the silver liner from a pack if cigarettes. Probably applied with white glue(elmers?).
2009 Dodge Charger R/T with Road & Track package
Old 08-24-2007, 03:07 PM
I kind of like the mesh idea more than the foil one for some reason lol so basically use mesh to get the pattern, and then apply some of that metal finish sprays (forgot name) to make it metal. right?
Old 08-24-2007, 03:38 PM
Since there are gaps after you assemble it, i think i might have to use foil after all to get the pattern...and to fell the gaps
Old 08-24-2007, 03:56 PM
klutz_100's Avatar
Cigarette foil, MFH Heat shield or Crazy Modleer PE set cointains a heat shield IIRC (but could be wrong).
TBH I don't think you will get a very convincing heat shield effect by spraying through a mesh
Old 08-24-2007, 04:07 PM
Razor Sharp Twit
never tried the mesh method myself and you would need really fine mesh and good paint+airbrush for the percision needed. On the other hand, on a larger scale, I've seen pretty good effects used on architectural models by spraying through various materials.
Best way though for cars, is to stick with the foil method.
As mentioned before, several manufacturers have a heat shield patterned product. It's the simplest, quickest and the easiest method.
AF's Guidelines
Read them.
Old 08-24-2007, 04:32 PM
cyberkid's Avatar
cyberkid cyberkid is offline
CM (full version, not sure on simplified) does contain a full shield where SMS super detailed kit only contains the upper half of the shield.
If you don't want to spend the money for PE stuff, then I would suggest cigarette foil.
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 08-24-2007, 06:56 PM
freakray freakray is offline
AF Modelrater
Marlboro cigarette packets
AF User Guidelines
Old 08-24-2007, 09:28 PM
klutz_100's Avatar
Actually, Gauloise sans filtres is a MUCH better source for foil
The paper is not glued into the pack so it does not tear when being removed and also there is no writing embossed into it, so the whole surface is 100% useful.
Old 08-24-2007, 09:49 PM
thx everyone!
Old 08-25-2007, 01:24 AM
sjelic's Avatar
sjelic sjelic is offline
This is Marlboro, now show me Gauloise
Smoking kills!
Sasa Jelic
SCALEMAKERS
Old 08-25-2007, 07:39 AM
AF Modelrater
As soon as Gauloise becomes freely available in the US, I will look at them for a source, in the meantime you can keep the smelly French cigarettes.
AF User Guidelines
Old 08-25-2007, 09:54 AM
klutz_100's Avatar
Sorry, I meant Gitanes. I couldn't see properly for the smoke...
They still beat weedy 'ol Marlboro's any day
Old 08-25-2007, 02:38 PM
jano11 jano11 is offline
What is that 166 mm doing in the background?
