Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 08-24-2007, 02:15 PM
javatrooper's Avatar
javatrooper javatrooper is offline
STOP the beeping please--seatbelts???
I need to turn off the seatbelt warning beeper and warning light that goes with it. My drivers side seatbelt that runs through the door is stuck in the back position which is just fine. But the warning beeper sounds off and on for no reason other than it's messed up. I just want to turn off the noise. I cut the wire running to the seatbelt under the drivers seat cause I thought that was the problem, and unplugged one or two of the wires in in the door running to the track, but none of that helped. What wire can I cut to stop the noise? I have a '94 Protege DX (I think) I know it's not an LX model. Any suggestions?
Old 08-24-2007, 03:43 PM
Doug Tatham Doug Tatham is offline
Re: STOP the beeping please--seatbelts???
I haven't checked on the Mazda, but a lot of them use a relay to make the buzzing or beeping noise. If so you may be able to pull the relay.
Old 10-23-2007, 10:11 AM
kh1p3h kh1p3h is offline
I have a 92 LX with a similar problem and I pulled the center console that covers the handbrake and the shoulder belts. I disconnected the plug that sits just forward of the two shoulder belt recoil assys. I connected a jumper between two pins on the driver side of the connection, but I don't remember which two. The dash light stays on, but no buzzer. I plan to revisit this issue to correct the problem at some point, but my 2do list is long.
