Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-24-2007, 01:56 PM
5046adam 5046adam is offline
Question need help with vatts (i think)
i have an 89 firebird a year ago i found out about vatts. I bypassed it with resistors from radio shack it's been working fine but now i think that its happening again or something cus the starter just clicks one time and i hear a whinning noise from the driver side kick panel, also the lights look to be loosing power or something cus they dim alot (brake light ,security). i measured the resistance on the insert i made and it was off by 107 so i soldered on an extra 100 ohm onto it but it still doesn't start. the battery is fully charged and the starter is good. actually the starter needed shims and when i took it off i could see where the flywheel had cut into the starter do u think the teeth on the flywheel got f-ck up. if so i thought the flywheel metal was harder than the starter hood. need help thanks guys
Old 08-24-2007, 02:27 PM
philly rs's Avatar
philly rs philly rs is offline
Send a message via Yahoo to philly rs
Re: need help with vatts (i think)
tell u one thing about the resistors...the camaro i have now was done that way, and it screwed up..the problem with the resistors is sometimes after awhile it starts reading outta the range it was set 2..let me try an explain it the way my boy told me...u have a certain amount they have to equal in order for the car to start, u can be off by a little bit.... if u are over or under by just a bit much it wont work...sometimes one of the resistors get jacked and sometimes it will read correct and other times it wont..thats why u can try an start the car and it wont then come back 10 minutes later and try and she fires right up...what i ended up having him do was the same exact thing i did with my old RS..instead of using the resistors use the black chip from your key...its the perfect resistor for the car, all u have to do is tap it out of the key, and get u 2 small peices of wire and sauder it in between and have the vatts bypassed with that...never had a problem with the RS since, and now i havent ever had a problem with the F1..the key chip is the exact ammount u try to reproduce with the resistors..the only problem is the resistors arent absolute all the time..i hope that helps u out. now as for your dimming problems....check the alt. battery, and even you maf...when mines started doing that of all the things i named...it was the maf sinsor...the car started wigging out and cutting off and the lights werent on too bright...it was a hott mess lol.
Your import sounds like my ass after a night of mexican food..
And spraying aint cheating, its brining a gun to a knife fight!!
yeah, its a v6 RS...never mind the f1 badges lol
HYPSI87 u will be missed
Old 08-24-2007, 10:57 PM
thanks, what did u use to tap it out without breaking it, or the key
Old 09-08-2007, 01:42 AM
jonsarb111 jonsarb111 is offline
If the other sugestion doesn't work, I had a problem with my RS that sounded the same as yours. I ended up having to remove the steering wheel and get into the column. Inside there is a very small yellow wire (starter kill switch) it has a tendancy to wiggle lose. If this is the case with your car, get a magnafying glass and a low wattage soldering iron and resolder the wire.
Good Luck!!
Old 09-28-2007, 02:23 PM
i bypassed the vatts with the pellet from the key and it was working fine for a few weeks but now it's doing it again what does it go to a body control module or something and where is it located -thanks
Old 09-28-2007, 02:33 PM
vatts again- help me please
i poped out the pellet from my key and soldered it on to bypass vatts(used radio shack before) it worked fine for a month or so but now its acting the same way again. i measured the resistance on the wires and its in range do u think the computer that it goes to is messed up any help will be appreciated
Old 09-29-2007, 05:31 AM
sdsniper's Avatar
sdsniper sdsniper is offline
http://www.ecklerscamaro.com/product...dept%5Fid=1620
This where i got my vats bypass. it works great.
Old 10-03-2007, 11:57 AM
can anyone tell where the vats box (module) is located at in the car.
Old 10-04-2007, 01:39 AM
CamaroRS92 CamaroRS92 is offline
From your description of what is going on here I dont think you are having a VATS problem.
If the starter is clicking (even one time) and you are hearing a whining noise from the kick panel area, then i dont think VATS is what's shutting you down.
I would seriously think about replacing that starter with a new one and have your battery load tested. The cells in the battery may degraded or shorted out and the battery is not giving full cranking amps to start the car (even though it appears to be fully charged)
Old 10-04-2007, 11:53 AM
i had both the starter and battery checked and both were good. the whinning noise seems to be comming from a relay(starter relay i think) in the bottom left driver side panel- i measured the ohm's from behind the pellet WHILE IT WAS PLUGGED IN and it was reading -1555 or something like that, plus i can see the wires and they appear to be going on top of the steering column but i wont know for sure till 2morow when i can lower the column. thanks for your help guys, but if anyone can think of something else please let me know....also the problem with the lights have been fixed since that time the starter was checked. So thats why i know it a vats problem maybe the module i hope
Old 10-05-2007, 01:16 PM
fu**ing shit man this piece of sh*t still wont start i went ahead and ordered that bypass from ecklers camaro the ohm is good but know i hear the fuel pump relay making alot of noise come on guys let me know something otherwise im selling the sh*t cheap lol
Old 10-09-2007, 12:52 AM
i fixed it
Old 10-09-2007, 08:10 PM
sdsniper's Avatar
Originally Posted by 5046adam
i fixed it
what was wrong with it?
