Old 08-24-2007, 10:24 AM
dpmurphy123 dpmurphy123 is offline
Help with Keyless entry programming
Ive seen alot of differnet instructions for this but none of them seem to work...i have a 16 pin connector but there is only a couple wires in it and niether is 4-8 i would say there is six wires...ones orange one black ones purple twos black and white and ones possible green...please give me sum suggestions its a 1998 buick park avenue wit factory alarm
Old 10-05-2007, 11:37 AM
2early 2early is offline
Re: Help with Keyless entry programming
Hello. Try the link below, it has all the directions for what you need.
http://ebiz.netopia.com/pyr/gm210
Old 10-07-2007, 04:44 PM
gaguirre gaguirre is offline
dpmurphy123,
I have just reprogrammed a new transmitter on my 98PA, the connector under the dash was upside down but the colors were solid grey and white with a blue stripe. I jumpered these wires turned the key to ACC the doors locked and I was able to program the new transmiter as well as the working one I had. I hope this helps
Old 10-09-2007, 10:24 AM
JESSICAR JESSICAR is offline
Send a message via AIM to JESSICAR Send a message via Yahoo to JESSICAR
I wish I would have seen a post like this or asked the question when I needed my Key Fobs programmed! When I bought my 1995 PA it didn't come with a Key Fob (dealer said it was lost). While at a junk yard, I actually found a pair of key fobs. Our local mechanic said they could program them by using a computer? Well ended up costing $17 for the batteries and $20 for the labor. Still cheaper then buying new FOBS but still, if I woul have asked the question, I could have probably done it my self...... Kick kick kick in the head!
Old 10-10-2007, 01:53 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Transmitter programming per the GM manual:
Important:
Before entering the programming mode, verify the possession of all the transmitters you will be using on the vehicle. Once you program the transmitter, the memory erases the other transmitters. You may program up to 4 transmitters
1) Turn OFF the ignition switch
2) Usa a fused jumper (3 amp is sufficient) and connect terminal 8 (back/white wire) to terminal 4 (black wire)
3) Close all the doors
4) Turn ON the ignition switch
the doors will lock
5) Press and hold the following buttons on one of the transmitters for 30 seconds:
lock and unlock
6) After a 30 second delay, the doors will lock and unlock
Important:
DO NOT turn OFF the ignition . If the switch is turned OFF the first transmitter becomes inoperative.
7) In order to program extra transmitters repeat Step 5
8)Disconnect the fused jumper wire from the data link connector
9) Turn off ignition
10) Verify functions of all programmed transmitters.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
