Temperature blend actuator
On my 2000 Silverado the heater would run hot and I could not get it turned down. I read somewhere that the actuator was bad so I ordered one and installed it but it worked for about 1 sec ,long enough to go to one side (don't know if it is hot or cold, it is still hanging down from the dash) but now it will not work. Is there a method to getting it started such as pulling a fuse , disconnecting the neg post on battery, or something else I am missing. Do you suppose the gears are locked to one side or is the control knob bad.
Re: Temperature blend actuator
Bruce: Your truck has a BCM (body control module). The controls for the heater/ac system go thru that along with a lot of other body functions.
MOST of the problems you described are fixed with a new control/switch panel. If you take the blend door motor out and leave it plugged in will it respond to commands? If not it's probably the control panel. There are ways to reset the BCM system, but I don't know what they are. Maybe some guys who are familiar with the BCM resets will step in and help you out. Just letting you know that someone is looking.
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
Thanks for that info... Does anybody out ther have the reset info he is talking about?? It is awfull hot in the cab this time of year..
Replace the control panel, Mine did the same thing, dealer replaced the actuator which did nothing to fix the problem. Finally replaced the control panel. luckily, mine was under an extended warranty. I dont think that the control panel was cheap.
