Old 08-23-2007, 04:24 PM
jetdoc55 jetdoc55 is offline
Eletrical dash warning light
1998 Blazer ABS, seat belt, security, alternator warning light come on,and go on and off randomly, and temperatureand fuel quantity drop off line after about 20 minutes driving. New battery and new alternator recently. Some times only the ABS comes on. At other they all are on then off randomely. Please help me.
Old 08-23-2007, 05:57 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Re: Eletrical dash warning light
Maybe try cleaning the battery terminals???
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 08-23-2007, 05:58 PM
old_master's Avatar
Advisor/Moderator
The first thing to check is the connector on the back of the instrument cluster. A female connector is mounted to the instrument panel, and a male connector is mounted to the back of the instrument cluster. When the cluster is installed, the cluster retaining screws are the only means of keeping the two connectors tightly together. If the screws that hold the cluster in place become loose, no tellin' what instruments will go crazy!
