Old 08-23-2007, 08:30 AM
bigdawg703 bigdawg703 is offline
2000 Taurus Airbag Light Code 46?
The airbag light just started flashing on my 2000 Taurus, it flashes 4 times then pauses and flashes 6 times the repeats itself a couple times then stays on solid. Does anyone know what this code means?
Thanks
Old 08-23-2007, 07:56 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
Re: 2000 Taurus Airbag Light Code 46?
drivers pretensioner fault (drivers seat belt buckle) either unplugged poor connection at buckle or buckle it's self (normaly buckle on taurus)
-=-=-DANE-=-=-
Old 08-23-2007, 07:59 PM
Thank You for Your Help
Old 08-25-2007, 10:53 AM
dugan50's Avatar
dugan50 dugan50 is offline
Authorized Vendor
Rivguy is correct. Usually the seat belt pretensioner itself will fail leaving an open circuit causing the light to flash that code. Once you replaced the buckle, the system should reset itself. For more info, check out this site:
http://www.airbagsolutions.com
and especially this page on pretensioners
http://www.airbagsolutions.com/docs/Pretensioners.pdf
Good luck
I hope this was helpful to you. My information comes from years of experience in these businesses.
http://www.airbagsolutions.com http://www.stolenandrecovered.com
Airbag Service, Airbag Replacement, Airbag Diagnostics
Thank You,
Douglas Gan
