Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > General Discussion
General Discussion All general comments or enquiries go here. Website, club oriented, or general Skyline banter.
Old 08-23-2007, 08:10 AM
BLISTK BLISTK is offline
Engine Knocking sound RB30
Hey people,
My Brother got a R31 Skyline from a friend for free. I took it for a spin and between about 1.5k to 3.5k rpm there is a knoking sound like metal on metal. I thoung that it might be lifters but when at idle there is no noise and same during cuise at 2k rpm.
I havent checked the timeing so i dont know if it could be detonation. It sound like it.
Also there seems to be a bit of hesitation when i accelarate.
Anyways any advice welcome. We are going to muck arround with it this weekend.
Old 08-24-2007, 07:30 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Re: Engine Knocking sound RB30
Sounds like it could be big end bearings, which is probably why it was a free car May also be the injectors squaling, which is common but does not cause any mechanical problems. Lifters are also a common problem.
RB30 motors are pretty cheap as they were also used in the VL commodore so when the existing motor goes bang, just put in a new motor
The RB30 motors are near indestructable though. I would recommend a 2.5" exhaust and a set of extractors if you want a bit more fun from the 3L motor though
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
Old 08-24-2007, 07:55 AM
Yeah but if it is the big end bearings would the noise be present at idle? I think that if its something mechanical it would be present through out the rev range.
Anyhow i will have a look at it in the morning to see what i can make of it.
And your right RB30 are very good engines i Have a VL T BT1 and this thing just puts out power like no tommorow. I has 275Kw @dweels anyways have a good weekend.
Old 08-27-2007, 05:26 AM
Ok,
Well now that i have spoken to my brothers frind that gave him the car I found that the Knocking started right after the engine overheated. But he told me the engine didnt sieze he just noticed that the water temp was high and pulled over. Filled it and drove home and then is when the knock started.
So from what i can gether to me its sounds like its the Rod bearingst. There loudest at about 2k to 2.5k. I pulled to top cover off and the valve train seems ok and the Spark Plugs look very healty no excessive corroding or carbon buildup. All well if am in the moode might take the oil pan off and a have a look up skirt
Does anyone here have a RB30 Manual in PDF of something??
What do you think??
Old 08-27-2007, 07:05 AM
mmcleo11's Avatar
Rod big end bearings are most noticeable between 2000rpm and about 3000rpm. I heard quite a few nasty rattles like that before...
You can use a screwdriver with a long handle and place the tip up against the block. The handle rests up against your ear and it acts as a good way of hearing the rattle in the block. If it is rattling, then the crank will be damaged and a secondhand motor with a 6 month/10,000km warranty is normally around $500.
Getting the sump off in a R31 is a right royal pain. Have to unbolt the engine mounts from the cross member and jack the motor up to get room to get the sump off.
N14 Pulsar
The workhorse...
Twin turbo 5.7L LS1
Old 08-27-2007, 08:30 AM
Where can you get motors like that??
Option 2 would be to rebuild it which might be fun but then again costly if we stuff something up, but it would be a lerning curve.
Hmm option 3. Take it to the paddic and thrash the shit out it till she goes
Option 3 strting to sound good
Old 10-18-2007, 08:10 AM
DanGee711 DanGee711 is offline
nah mate!its sounds like your hydraulic lifters have give up the ghost,big end bgs knock on initial acceleration!rev quickly and if it bangs its big ends!
tapping at low revs is valve train!
