Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-23-2007, 03:10 AM
lostmypicks lostmypicks is offline
j pipe problems
some of you might recall that I blew my stock t-25 turbo in my 98 talon.
I bought a new 16g turbo to replace it. the turbo is installed and all of the lines etc... I bought an install kit for it, well all that is left to install is the j pipe that goes from the turbo to the intercooler piping. I bolted it on and it pressed right up against my radiator fan and is pinching the wires and is stopping the fan from being able to move. I am not sure how to fix it.
if any of you have an idea or have had this happen I would love to hear what you have to say
thank you
ben
Old 08-23-2007, 08:55 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: j pipe problems
I know they make several different j pipes. Are you sure you got the right one for your car? Does it line up with the intercooler pipe?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-23-2007, 11:25 AM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: j pipe problems
Can you get any pics up of the setup? When i still had my stock fans in, the factory j-pipe going to the sidemount fit perfectly. When i got the new J-pipe for my FMIC it curved out towards the drivers side and would hit up against the fan shroud. I ended up taking the fan out and taking a hammer to the metal shroud so it wouldnt be rubbing up against it. But, i didn't have any problems with it coming in contact with any wires and affecting the performance of the fan.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 08-24-2007, 02:30 AM
Re: j pipe problems
well I found out why the fan is not working it is broke. but no worries I just took it out and then I had tons of room. I figure that if the fan was not working when I was driving before the turbo blew then it should be fine now. it is the ac fan I never use it anyway. so I got every thing together and started the car. but I do have to fix one little leek, the oil return line were it bolts to the oil pan leeks but not bad at all. I think I will just clean off the surfaces and put it back together with rtv compound ect...
this is my first turbo upgrade so if there are any suggestions or things I should know I would love to hear them
thanks to all
ben
Old 08-24-2007, 10:41 AM
Holset powered 420a
Re: j pipe problems
Might want to be careful takin out the ac fan. I took mine out bc I didn't have the room and now my car overheats when the ac is on. So I cant use it. That also could be bc of my fmic to. I just bought a smaller fan to put in there.
98 Eclipse GS Turbo
2001 BMW 325i - DD
