Go Back   Automotive Forums Car Chat > Ford > Contour
Old 08-22-2007, 10:06 PM
BAwebfoot BAwebfoot is offline
Send a message via AIM to BAwebfoot Send a message via Yahoo to BAwebfoot
1995 Ford Contour V6 Fuel Pressure Regulator
Anyone know where the fuel pressure regulator is located on a v6 1995 Ford Contour ? Can't seem to see it. Does something have to be removed to expose it?
Old 08-23-2007, 08:15 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: 1995 Ford Contour V6 Fuel Pressure Regulator
Its right below the throttle body attached to the lower intake manifold. If you can find the schraeder valve which is attached to the LIM as well, you can trace your way back to the FPR. I highly doubt your FPR has gone bad and causing your problems though. About the only that could happen is the vacuum line fell off the nipple on top of the FPR causing you to run full pressure with your fuel.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
