I have just received a 95 lumina from my sister-in-law. I had repaired her ignition problem once before by soldering her extra key to the wires under the dash because it wouldn't start due to the resistance not working at the ignition. It has run fine since but now it is having problems with a lower headgasket. She is getting a lot of coolant in the oil and it is now sitting in my driveway waiting to be signed over to me. I am wondering One; is changing the head gasket a huge job, and two; I am very mechanically inclined but have never really gone to the depth I am assuming it will take to change them. There is a slight knocking in the engine, but it comes and goes. The car ran fine before it was parked just a week ago, and I know that knocking can mean some really serious issues, but if there is anyone who can help me I would sure appreciate it.
Re: Lumina 95 Headgasket question
The lower intake gasket is more common than the head gaskets. The coolant will destroy the main bearings pretty fast if driven with coolant contamination.
A piston skirt slap when the motor is cold is common with 3.1's, and they have various other clatter from valve train and sometimes timing chain tensioner...if it comes and goes it's probably not too serious. Once you get the leak fixed, change the oil with the cheapest crap oil you can get (try Exxon Superflo at Autozone), then change the oil and filter again in a couple hundred miles with some good stuff and see what you got...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
1994-96 VEHICLES
See Figures 19 and 20 Fig. 19: Unfasten the retainers, then remove the upper manifold Fig. 20: Lower intake manifold removal-1995 3.1L engine shown
Don't forget to properly bleed the cooling system when done, and don't mix up any pushrods you remove...
