Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 08-22-2007, 08:14 PM
superj26 superj26 is offline
temperature gauge needle 03 galant
the gauge needle used to shake quickly when i go over over bumps like it wasnt working but now it doesnt move at all.......is it that the gauge is bad??, thermostat is stuck??, a simple fuse or wire went bad???, or could it be something else???
the car runs fine, the a/c still works great, no fluid leaks, radiator is full. PLEASE HELP!
Old 08-23-2007, 06:33 AM
sparkeykev sparkeykev is offline
Send a message via Skype™ to sparkeykev
Re: temperature gauge needle 03 galant
Locate the temp sender in the engine bay check the wire is still connected if it isnt re conect it if it is connected ground the wire to engine block the needle on gauge should go to hot if not check wiring to gauge of gauge is faulty
