Go Back   Automotive Forums Car Chat > Ford > Contour
Old 08-22-2007, 04:30 PM
BAwebfoot BAwebfoot is offline
Send a message via AIM to BAwebfoot Send a message via Yahoo to BAwebfoot
1995 Ford Contour v6 engine light
Have a 1995 Ford Contour GL with the v6== Engine light would come on at high RPMs and then go out at lower speed--Engine would miss at high RPMs. Changed the fuel filter and now the check engine light will come on at lower speeds== it does go out -does not miss at lower speed. Possibly the fuel pressure regulator? Where is it?
Old 08-22-2007, 06:21 PM
Selectron Selectron is offline
Re: 1995 Ford Contour v6 engine light
I'm not familiar with your vehicle, but this is from the Ford service manual for the '95 Contour 2.5L V6:
«1995 Contour/Mystique Table of Contents»
«Group 03: ENGINE»
«Section 03-04B: Fuel Charging and Controls--2.5L»
«DESCRIPTION AND OPERATION»
Fuel Pressure Regulator
The fuel pressure regulator:
Is attached to the fuel injection supply manifold downstream of the fuel injectors.
Regulates the fuel pressure supplied to the fuel injectors.
Is a diaphragm-operated relief valve in which one side of the diaphragm senses fuel pressure and the other side is subjected to intake manifold vacuum. Nominal fuel pressure is established by a spring preload applied to the diaphragm.
Balances one side of the diaphragm with manifold pressure to maintain a constant fuel pressure drop across the fuel injectors.
Bypasses and returns excess fuel to the fuel tank.
Old 08-23-2007, 09:15 AM
taillight taillight is offline
Get a scaner and pull trouble codes.
