Old 08-22-2007, 02:40 PM
hanniep hanniep is offline
Power Window won't work
1994 S10 LS ZR2, When depressing the drivers side power window switch, it makes a "rapid" clicking noise and the window will not work, this just started happening, any ideas???
Thanks
Phil
Old 08-22-2007, 02:56 PM
sheadogsavannah sheadogsavannah is offline
Re: Power Window won't work
I just had to have my window motor and regulator replaced. My window would go down about 2" and then start making a funny noise, but wouldn't go down any further. The regulator was bad, but the shop told me I might just as well replace both the motor and regulator at the same time to save on future labor if the motor went bad. This was on a 2000 Bravada.
Old 08-22-2007, 03:12 PM
Thanks, How much did you pay?
goser goser is offline
Sounds like a window motor gear problem. If you pull off the door panel you should be able to see the problem right away. Replacing the motor/regulator is pretty easy once you get in there.
A regulator from the boneyard should be less than 50 bux, or get new/referb off ebay.
'01 Chevy Blazer ZR2 4x4 VIN=W
'80 Yamaha XJ650 Maxim
'08 Jeep Patriot 2.4L
Old 08-22-2007, 03:28 PM
My total cost was $398. That included a new motor, regulator and labor. I didn't want to try it myself. I was afraid that I would screw it up and have to have a professional do it anyway.
