Old 08-22-2007, 12:18 AM
mike8818 mike8818 is offline
Send a message via AIM to mike8818
D15 to B18???
i did some seacrhing but it dosent tell me. What do i need for the swap, the whole harness, engine, or under dash too or just the whole thing? And also what axels can i use for it. its in a 1991 crx
1979 pontiac firebird- for sale/trade
1978 Chevy Elcamino- parting out
Old 08-22-2007, 12:43 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: D15 to B18???
Most of the time you want to use your factory harness. You will need to do a DPFI to MPFI swap first.
You will use the B18 axles, just have to remove the dust rings at the end.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 08-22-2007, 12:48 AM
Re: D15 to B18???
Yeah but what do i need for that swap?
Old 08-22-2007, 01:04 AM
Tony's Avatar
TLD Member #1
Re: D15 to B18???
Check here
Should answer most of your questions about most of the details. In short, you will need: Engine, Cable Transmission, ECM, Shifter linkage, and a Motor mount kit. For the MPFI you will need the injector resistor box also, along with running the extra wires to the ECM for it.
I think thats the big things you will need. Depending how much you wanna spend, the mounts can range from $100 to like $4-500, maybe more. I got mine off Ebay for $120 I think...still haven't swapped the motor, but they seem to be really solid mounts and they retailed for $400.
Tony
Old 08-22-2007, 01:09 AM
Re: D15 to B18???
kk thanks alot for your help
Old 08-22-2007, 01:18 AM
Tony's Avatar
TLD Member #1
Re: D15 to B18???
Not a problem. I have that link bookmarked because I use it alot too. I gotta do this swap, including the MPFI, sometime in the next week or so.
Tony
