Old 08-21-2007, 10:43 PM
cmjrbking123 cmjrbking123 is offline
Help :(
ugh one of the wires broke on my map sensor that why i think it's throwing a code. How do i fix the broken wire? do i get a new conncetor or something?
any help would be great thanks.
Old 08-21-2007, 11:15 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: Help :(
you can remove the pin with a pick or tiny screwdriver..then either solder the wire together or depending on how much is left..remove the smaller broken piece and solder the wire to the pin, then replace.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 08-21-2007, 11:28 PM
Re: Help :(
hmm i will try that. hope that works. what if i cant find where the wire is broken? guy i got it from said it was but i dont see it. should i test it with a volt meter?
Old 08-21-2007, 11:54 PM
FrodoGT's Avatar
Re: Help :(
Yes, and if all else fails..simply run a new wire to the ecu.
Current project:
Rio Red 91 hatch.
