Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-21-2007, 09:22 PM
chunk-it chunk-it is offline
Lightbulb old fan swith wire burnt up that was jumped out from the fan relay to the pcmign fuse
If you connect it back the way it was the car will stay turn on. It's ready to start even with the key out. plus the switch doesn't even work now. I'm going to pull the fan tomarrow and trace the wires. how can i hook it up correctly and did I mess the computer up aswell?
THANKS
Old 08-22-2007, 02:37 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: old fan swith wire burnt up that was jumped out from the fan relay to the pcmign fuse
cooling fan failures are a common problem, most of us just chalk it up and run a switch allowing us to control the fan manually. In my opinion, you should replace the switch with a heavier duty one, and run the wire directly to the battery instead of the fuse panel.
