Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 08-21-2007, 07:32 PM
SarahGuess SarahGuess is offline
Talking If You Have 04 Escape Click Here
I have a 2004 Escape and have remote keyless entry key fob that I need to program. In order to program it I need the FCC number for the remotes that are for 04 Escape. You can locate this number on the back of your remote keyless entry fob. Please respond with the FCC numbers. Thank you!!!
Old 08-21-2007, 08:20 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
Re: If You Have 04 Escape Click Here
for what - cycle the key 8 times and after the locks cycle or a chime sounds - hit any button and it's programmed to the vehicle.
-=-=-DANE-=-=-
Old 08-21-2007, 10:56 PM
carlos80 carlos80 is offline
If this doesn't work try locking and unlocking the doors with lock/unlock switch first before doing the cycling key 8 times procedure.
Old 08-22-2007, 02:24 AM
Hi, I have already attempted that, and that did not work, so I was advised to get a remote that matches the FCC eto that make and model. Do you have any other suggestions of why the 8 times did not work, or what else I can try??
Old 08-22-2007, 02:28 PM
On the eight cycle the key must stay on and all doors must be closed. Did you try locking and unlocking locks with button on door panel before going through the 8 cycles?
Old 08-27-2007, 04:20 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
FCC: CWTWB1U212 or CWTWB1U331 both work.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
