Old 08-21-2007, 07:00 PM
crazybarracuda crazybarracuda is offline
99 jimmy cranks but dont start
okay my girlfriends gmc jimmy will turn over but will not fire. it sounds like it is almost about to fire.
Things i have checked. fuel pump is working (hear it running)
plugs are decent
when i tested the spark there was no spark across the plug i had out of the cylinder.
what could it be
Old 08-21-2007, 07:07 PM
old_master's Avatar
Advisor/Moderator
Re: 99 jimmy cranks but dont start
Check for spark at more than one plug. Make sure the plug is grounded. Spark should be blue, not orange. When were the distributor cap, rotor and spark plug wires replaced last? Always check fuel pressure with a gauge. Just because the pump is running, doesn't necessarilly mean it is building proper pressure, and able to hold it.
Old 08-25-2007, 02:31 PM
xtremeblaz's Avatar
xtremeblaz xtremeblaz is offline
Send a message via AIM to xtremeblaz Send a message via Yahoo to xtremeblaz
I am having similar issue with mine starting. got my truck scanned and shows the coolant temp sensor is bad. but about your fuel pressure you need 60psi to get it started.
Old 08-25-2007, 06:39 PM
Blazin_Jason Blazin_Jason is offline
Might want to change out the ignition module.
Old 03-16-2009, 08:24 PM
tdavis0596 tdavis0596 is offline
I`m Having simalar problems its a friends car and he did a intake gasket repair on it . And now wont start. I put a inline spark tester on the coil and its getting fire . And i can smell fuel . But wont crank I pulled the dist. and put the rotor pointing at 1 plug and still nothing and also tried rotating it again thinking maybe 180 out but still nothing. can you help me also with this I`m am tired of fooling with it and it`s ony been 3 days working on it thank You
Old 03-17-2009, 02:50 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Welcome to AF.
Please check date on post and let the old dogs lie in peace.
Waking up a sleeping dog can get a person bite.
also
Please start a new thread with your question here:
http://www.automotiveforums.com/vbul...wthread&f=2072
MT
