Old 08-21-2007, 06:47 PM
goofyhomer2006 goofyhomer2006 is offline
Smile oil pressure
My 1998 blazer oil pressure is reading 1000 rpm.6 -10 psi, 2000 rpm.around 18 psi
and at 3000 rpm.24-30 psi, is this too low, if so where is the oil pressure sending unit located, i've read that usually that is what goes out.
Thanks
Old 08-21-2007, 08:22 PM
old_master's Avatar
Advisor/Moderator
Re: oil pressure
1998 S/T series 4.3L oil pressure sending unit is next to the distributor, and just to the driver side. Before you start replacing parts, perhaps unnecessarily, it's best to check the oil pressure with a manual gauge, (they are far more accurate) just after changing the oil and filter.
