Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 08-21-2007, 06:44 PM
pondhaus pondhaus is offline
Question 2004 Transmission Bucks between gears
For the past 3 weeks, my transmission bucks right before it shifts and is getting worse day by day. I had a tune up less than 2500 miles ago. I checked the transmission fluid and it looks fine. The check engine light came on 2 weeks ago and I changed gas stations as the manual suggested in case it was that and the light did go away. Before I bring it to be looked at, any suggestions?
Old 08-28-2007, 09:10 AM
INF3RN0666 INF3RN0666 is offline
Re: 2004 Transmission Bucks between gears
Look at the transmission fluid again. If it has bubbles, you have a pressure valve problem. If it smells burnt and like metal, then you're grinding gears. If it's discoloured, you may have contamination. I would take it in asap if you value your transmission.
Old 08-28-2007, 09:14 AM
Sorry, I forgot to tell you to check your transmission fluid WHILE THE CAR IS RUNNING. Drive it around for 5 minutes in all gears, including reverse. Then park it on a level surface and keep the car running while it's in park. Then check your trans fluid.
