Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 08-21-2007, 05:45 PM
Tombonius Tombonius is offline
Cool 2000-2006 Bonneville Door Panel Removal
I have seen a lot of questions aobut door panel removal, but haven't seen any answers for 2000-2006 Bonneville since they are a little different. There are NO screws to remove on the door panels. You need to first insert a flat screwdriver around the bottom of the door panel and work your way around pulling out the plastic holders. You can then pull the top of the door panel directly out from the window. The door panel should now be loose with the exception of the very center of the door. Now, pull the door panel straight up until the clips in the center of the door slide out of their holders. It takes a bit of force but it will work and nothing will break.
