Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 08-21-2007, 04:03 PM
blksuperman409 blksuperman409 is offline
camshaft position sensor
Where Is The Camshaft Position Sensor Located?
Old 08-22-2007, 05:52 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: camshaft position sensor
I't would help to post year and engine size.
Welcome to AF
In future posts, it would help to post both year and engine size. I'll assume you're talking about the 03 in your profile. IF you have the 3.4 engine, it is in the center "V" of the block on the passenger side just off the end of the intake manifold. You'll have to remove the power steering pump to acccess/change it. If you have the 3800 engine, it is located in the timing cover just above and toward the rear of the car from the harmonic balancer (about 10 o'clock).
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-22-2007, 09:03 PM
PAman PAman is offline
And the 3.4 is very not-fun to replace. Be sure to take your time and have proper tools. Don't drop anything in the hole after you pull it, either!!! The sensor sticks down to the cam vertically from behind/under the PS pump. Plastic pump pulley is fragile, too.
